I was told on another board that you can actually record HDTV but it
will convert it down to 480i that will look about the same as playing
a DVD and slightly better than regular TV. I was told the advantage
was that it will record in 16:9 format even though it's only 480i. Is
this true?
This person told me I'd have to go with S-VHS though instead of
regular VHS but I have a DVD Recorder. Will this record like that as
well?
This person mentioned that the Hughes box can be selected to do this.
Do all HDTV boxes do this and does it do it if you hook up through
S-Video or component or is it something you select in a menu?
Results 1 to 1 of 1
Panasonic DMR-HS2 power on failure
By rmhartman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Feb 2012, 15:19 -
Panasonic DMR HS2 (Setup Mode?)
By philo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2009, 13:14 -
Panasonic DMR-HS2 - shuts down when I try to record
By donmeyer2 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Sep 2008, 23:35 -
Problem with Panasonic DMR-HS2
By rmhartman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2008, 16:07 -
Problems with connection with my Panasonic HDTV and Timewaner HDTV box...
By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 23:39
