Hi all,
I once heard that about 1 hour of of captured video can be placed on one 700MB cd-r by converting it to MPEG-2.
Can anyone point me to settings i need to use to obtain this rate. Everytime is use TMPGEnc to convert an AVI to MPEG-2, i end up with files that are much larger than 1 hour=700MB.
I would like to have information on what settings to use in TMPGEnc to get these results. With this i mean CBR or VBR and what rates mostly.
Henk99
Only thing that determines what movie duration you can cram into a given space (= file size) is the bit rate. For CBR this is the bit rate period. For VBR it's the average bit rate.
To get 1 hr of video on 700 MB, you have about 1500 kbps video at your disposal, together with 128 kbps audio.
If you however encode to (S)VCD compliant mpeg, you can author as (S)VCD, giving you almost 800 MB space on a 80 min CD-R, allowing for nearly 1600 kbps video with 224 kbps audio.
/Mats
Decoding LG HB966TZ
By mikestar in forum Blu-ray RippingReplies: 2Last Post: 20th Oct 2011, 05:19 -
subtitles gone after decoding
By Meredy in forum SubtitleReplies: 1Last Post: 7th Jul 2009, 08:52 -
Cuda decoding
By b33rman in forum Blu-ray RippingReplies: 4Last Post: 28th Feb 2009, 09:46 -
Xvid4PSP and DD decoding
By CineManno in forum Newbie / General discussionsReplies: 8Last Post: 25th Jan 2009, 12:55 -
DTS Decoding
By Neutral-Sage in forum AudioReplies: 8Last Post: 17th Nov 2007, 03:16
