Hi folks.
I used "Decompress" to convert a DivX to pCM. It seemed to work ok. Then tried to convert the pcm avi to an Xvid using Vdub. Using Fast recompress, Xvid codec compression, audio Full processing and the Lame MP3 codec. I get the following error message:
Error decompressing video frame 26520:
An unkown error occured (may be corrupt data).
(error code - 100)
Any advice?
I am doing this to convert the original DivX avi to mpg for VCD burning. Using TMPGEnc and an extracted wav I get sync problems. No sync when I do the same with an Xvid avi, hence trying to convert the DivX avi to XviD avi,
Regards
fiiido
