  1. Hi.
    I am trying to rip a dvd to transfer on a vcd, but with the audio commentary of the director. I am using DVD decrypter, then dvd2avi and Tmpge but with no luck. I select the audio track with the commentary, and the video, but with no success. I always finish woth the original audio.
    Do I have to demux or something else? It's the first time I try to do this. If someone could give me some points to follow, I would appreciate very much.
    Thanks in advance.
    Xico
  2. in dvd2avi, you need to select the audio track that corresponds to the director's commentary.
    one way to do this is to play the actual DVD on your computer and select the director's commentary. then right click on the screen (when you're playing the movie) and look at which audio track is being selected. it's usually the first english track after the foreign language tracks, if any.
