can i play the dvd-r(after the recording)in dvd player that in the spec said that it support in dvd video format but no said that it support in dvd-r?
Results 1 to 9 of 9
Not necessarily.
If it doesn't specifically say it supports DVDR the only way you'll know if it works is to test it out (I usually take a test disk with me to Best Buy before I buy a new player -- this is also a good way to determine if the disks you make are compatible with other brands)."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
the sales man told me that the dvd recorder record on dvd-r disk but when i do the finalizing it convert to regular dvd(dvd video) , it's true?
It sounds like the salesman doesn't know much more than you do about the whole thing -- sorry, I'm not trying to be unkind.
A DVDR is a DVDR -- nothing will *change* it into anything different. What the salesman is referring to is that it needs to be "finalized" so that it will play on those players that support DVDR. That doesn't make it a commercial DVD, and it will NOT play on any player that doesn't support DVDR.
So look up your player and if it doesn't support DVDR, then it won't play your disk. Plain and simple (just buy a player that will -- most players made in the last year or so play DVDR just fine)."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
thank you very muth mkelley! you help me a lot!
i have the pionner 535k dvd player how can i find out if it support dvd-r? -
You could look on the left here -- where it says DVD Players.
People have reported information for various makes and models. Here are the Pioneer players (with yours listed)
https://www.videohelp.com/dvdplayers.php?DVDname=Pioneer&Submit=Search&Search=Search
According to this list that player does indeed support both + and - DVDR, so you should be just fine (well, as fine as these things ever go...)"Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
it's very weird because in most spec of this dvd no said that it support dvd-r but in your link said that it support dvd-r!!!
look at this fo rexample: http://www.gamestech.com/dvd_info/pioneer/dv_535k/pioneer.htm -
The link you posted doesn't say it *doesn't* support DVDR -- it just doesn't say that it does.
The players database here on this site lists people's experience with the units, and not necessarily the manufacturer's specifications.
Obviously, if a manufacturer says something supports something there is more weight behind it, but just because it doesn't list it doesn't mean it won't work. Prior to the last year or so most companies didn't say their units supported DVDR because, quite frankly, no one could really create any (well, *very* few people) and it wasn't something they either tested nor worried about.
But if you already have this player just go ahead and test it yourself -- if you can't currently create a DVDR I'm sure you can find a friend nowadays who will. It if works then it works."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
i sent the question to "codefree" company: can i play the dvd-r(after the recording)in dvd player that in the spec said that it support in dvd video format but no said that it support in dvd-r?
their answer:" Hi,DVD-Video will support DVD-R".
they saying the truth???
and if they did it's meen that every dvd player could play dvd-r even if it's not saying in it spec that it support dvd-r?
Panasonic recorder parts compatibility
By rmhartman in forum DVD & Blu-ray RecordersReplies: 4Last Post: 4th Feb 2012, 17:01 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
Canon HV30 / DVD Recorder compatibility
By davideck in forum DVD & Blu-ray RecordersReplies: 4Last Post: 18th Jun 2008, 19:39 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 04:54 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
