Is there a limit on the size of a file at 4 Gigabyte? Whenever I try to create a DVD image file over 4 Gigabytes, it stops and says out of disk space, but under 4 Gigabytes it is ok.
If so, is there anything I can do? I don't want to waste my DVD-R capacity.
There is a 4GB filesize limit on the FAT32 filesystem which win98 and winme uses. If you upgrade to XP NT or 2000 you can change your filesystem to NTFS which supports filesizes far in excess of 4GB
I am using Window XP right now. But the problem is, do I have to format the harddisk again? May be I chose FAT32 when I first format the harddisk.
No you do not have to format.I changed my second hard drive to ntfs,using the instructions i found on microsofts website.Do a search in the xp knowledge base,and it works.A couple of dos commands and its done.
bmiller,ont.canada
Problem with creating AVCHD file for ps3 using MultiAVCHD. Please help...
By Mike789 in forum Authoring (Blu-ray)Replies: 0Last Post: 22nd Dec 2011, 15:28 -
Creating Youtube (mp4) from mp3 and image
By robertpnl in forum Newbie / General discussionsReplies: 5Last Post: 6th Aug 2010, 09:11 -
Creating simple text/image to prompt 'Insert Disc 2'
By rbatty11 in forum EditingReplies: 11Last Post: 15th Feb 2009, 12:08 -
Creating cartoon video from JPG image
By richnz in forum Newbie / General discussionsReplies: 2Last Post: 5th Jan 2009, 15:18 -
Problem creating a dvd that works on standalone players from .avi xvid file
By brycej817 in forum Authoring (DVD)Replies: 4Last Post: 17th Apr 2008, 17:50
