Results 1 to 10 of 10
  1. I'm tryin to delete a vob on a movie im backin up.
    The Guides i've read on how to do this always mention using a Blank Vob but where do you get a blank Vob from????
    Please Help Me!!!!
    Just make a text document and rename it to "whatever.vob" and you have a black vob
  3. I'm Not quite sure what you mean.....
    a txt document..... like using note pad that can't be right can it!!!!
  4. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    yes note pad..but rename to VOB outside NOTEPAD cause it has the annoying habit of adding a .TXT extension to the file which will defeat what youre trying to do!
  5. I thought it would of been a lot more compicated.....
    Thank you for the help
  6. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    As long as nothing is going to access the vob that might work. A vob file is a container, and there can be all sorts of things in it. Yes its video but the layout of the video will vary. Because of that its hard to just make a "Blank Vob" that will work in every curcumstance.
  7. Or you can create a zero length file by doing this.
    1) Go to a command prompt
    2) at the command line type:
    copy con blank.vob
    3) Press Enter
    4) Press F6
    5) Press enter
    Zero length file created!
  8. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    there is a 12kb blank vob file HERE, you just rename it to whatever you want
    but 1st strip all the VOB ID's apart from one, then replace the original stripped VOB with the blank VOB and simply use VOB EXTRAS again to strip but this time keep VOB ID1#1 and this will keep the DVD structure valid
    what guides you reading?
    are they mine from HERE?
  9. Yeah makem i read your guide its good....
    i just didnt know where to get the blank vob from.....
    thanks to everyone that helped
