I am looking to buy a capture card, and currently I am liking the looks of the dazzle dvcII. One question that I have about this card is will I be able to capture video from a replaytv's vcr out with this card.
Pity,
You should not have a problem capturing from any composite or S-Video source. But, if you are not averse to taking things apart, you may want to do some searching on the net about the ReplayTV. If I remember what I have read correctly, it is possible to copy the recorded video stream directly from the ReplayTV unit to your computer hard drive, but it requires taking the drive out of the ReplayTV unit and attaching it to your PC, then replacing it in the ReplayTV unit.
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 07:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 15:16 -
Resizing video from ReplayTV
By Dougmeister in forum Video ConversionReplies: 0Last Post: 14th Oct 2009, 07:09 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 10:49 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 12:40
