Hi,
I've been using TMPGEnc to convert DIVX videos to DVD M2V files, in the past with no problem. With my last two conversions, however, TMPGEnc is creating video output information that continue on, after the original film should end. This extra "video" is basically stills from the movie and can add 5-7 gigs on to the file which is normally around 4 gigs.
Very strange stuff.
Any ideas what might cause this?
I'm sober while I'm working on this
Thanks,
Jim
Open up the divx file in vdub, does it report that the audio is encoded with VBR. TMPGEnc does not handle VBR audio well and causes problems. If this is the case save the audio out as an uncompressed wav file (using vdub full processing mode), and use this wav file as the audio source in TMPGEnc.
Thanks for the tip. It very well might be VBR, but I don't process the sound at all with TMPGEnc. Instead, I just convert the video, and then I use a slew of other programs to rip the sound and convert it to AC3. I will try removing the sound from the original and converting the video and see if this does the trick.
-Jim
cannot save file path too long
By masadar in forum Video ConversionReplies: 8Last Post: 26th Dec 2014, 02:56 -
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 18:25 -
How to get output file size before converting a file using ffmpeg?
By hayden in forum ProgrammingReplies: 1Last Post: 26th Feb 2012, 08:04 -
405mb vob file only 6 seconds long????
By tuckdog in forum Newbie / General discussionsReplies: 1Last Post: 20th Jun 2011, 03:51 -
Long file name in DVD player
By Shaorin in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2009, 22:00
