Hey all, I've been struggling for weeks now trying to convert grandpa's 80th B-Day video to MPEG-2 to burn to DVD for the relatives. When I use TMPGEnc I get a high pitched noise in the background. Also, it occurs with the Roxio, Ulead, etc. DVD authoring progs. However, when I use Main Concept's Encoder it works like a charm! However, I don't have the $149 to buy the program. Does anyone know what the difference is and how I can get TMPGEnc to work? As far as I can tell the settings are the same. Please . . . the 4th is coming up and I want to surprise people. I wanted to do this at a grad party 2 weeks ago, but couldn't get the high-pitched sound out. Thanks for ANY and ALL help anyone can give me!![]()
Try using an external tool to handle the audio encoding (i use toolame)
I had all sorts of probelems with the built in encoder, background hiss, tinny sound ect. It all stopped when I switched audio encoders. -
Tried toolame but it would bail after creating the initial wav file. Illegal audio or something. Any suggestions?Originally Posted by jarvizo
Use toolame INSIDE TMPGEnc (in the invironmental settings) to make the mp2 stream . Under the "external tool" tab, check the dialog box, then browse for where you have the toolame program.
I did this and I still get an illegal audio stream or something like that. I have no idea what's going on. I use XP, is there a problem with that OS?Originally Posted by jarvizo
Decode LG HB405SU
By ShaunA in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Jan 2011, 09:43 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57 -
Sound turned to white noise when using TMPGEnc Xpress & DVD Author
By Hal05154 in forum Authoring (DVD)Replies: 4Last Post: 15th Jan 2009, 23:03 -
What is being used to Decode?
By tb582 in forum Video ConversionReplies: 12Last Post: 9th Sep 2008, 16:15 -
How to emulate the Video Noise filter in premiere pro on TMPGENC Express 4?
By hanugro in forum RestorationReplies: 5Last Post: 25th May 2007, 05:11
