I live in Australia where we have the PAL B/G standard. I have purchased a Leadtek Winfast TV2000 XP Deluxe but found that the bundled software is not capable of capturing at 480*576 (PAL SVCD). This card uses the Conexant Fusion 878a chipset. Looking on the forums I get the impression that the TV2000XP does not allow capture in a number of resolutions including 480*576 but other cards with this chipset are capable of doing this. Is this true?
I used a number of 3rd party MPEG-2 real time capture applications and found none would allow me to select 480*576. I found that nanoDVR had a specific option to select PAL SVCD 480*576 but when I did it returned an error saying "not available-hardware issue" or something like that. It seems the card has been neutered or this option disabled for some reason.
What I want do is record in MPEG-2 real time at 480*576. I don't want to have to re-encode from another resolution. I want to be able to burn to direct to CD. Does anyone know a card that can do this?
Results 1 to 11 of 11
I'm expecting to get flamed for this response but hey
I bought a Snazzi DVC II from Harvey Norman and found that it works extremely well with what I want to do.
It quite happily records 480x576 at many different bitrates
it will also cap at most sizes between 320x388 >> 720x576
As well as 352x576 which I use to make CVD's
I have only had one issue with this card and that is it crashes recording MPEG 1 under Win XP Pro
Which suits me fine since MPEG 1 looks poor on this card
However MPEG 2 encoding works well and looks good
I think the Snazzi DVC 3 has replaced the II - but I think the main difference is software based, not sure on this part though -
How much did it cost? I'm looking for something that is cheap so no hardware encoding.
uhh I paid I think $700 for it
but you might still find a couple floating around for less
or search through ebay.com.au or trading post -
My apologies. I should have mentioned my primary aim is to record TV. So I would like t get a combo card TV Tuner/MPEG-2 realtime software encoder thaty encodes at 480*576 (PAL SVCD)
Then I think one of these
http://www.provideo.com.tw/
I have seen a couple floating around in the shops - but a while ago and I don't know exactly how well they work
Or even where you could get on here -
bunyip,
i see that you have dvd burner, so for you the best choice would be to capture in CVD aka 1/2 D1 aka 352x576, and then burn DVD.
note that only the latest winfast pvr supports this resolution. -
Thanks for the responses. I am not bunyip. Bunyip lent me his account to post because I might need to take this card back to the shop today to get a refund. I could not wait the 24 hrs that is required for new members to post. Sorry about the confusion.
Hi mate,
I use the same card, and we use the same system.
The PVR software that came with the card can capture in different sizes.
Or use an other program, like iuVCR.
You can get a good capture even at 705 x 576 with Mjpeg compressor.
Greetings,
Marco
I would recommend an ATI AIW radeon. I have the 7500, does a great job.
You can get the 64MB Hercules 3D Prophet - All In Wonder 9000 Pro now for just over £120, just a reboxed ATI card.
Features
The Latest 3D Technology For High Framerates in 3D Games
3D architecture powered by ATI’s RADEON™ 9000 PRO Visual Processing Unit (VPU)
Supports the latest 3D technologies for excellent fluidity, real-time animation of complex characters and realistic lighting effects: SMARTSHADER™, TRUFORM™
Full support for current and future 3D games
Transform your PC into a TV, VCR, and DVD Player
Stereo TV tuner (PAL B/G/D/K/I and SECAM L/D/K) with digital VCR and up to 125 channels
Complete set of amazing TV and DVD features
Integrated Teletext and TimeShifting functions (TV-ON-DEMAND™)
User-friendly DVD player: ATI Multimedia Center software package
THRUVIEW™ for translucent TV, DVD and video file viewing
Simple and Complete Solution for Creating Exciting Videos
Capture still images and videos from an analog camcorder in MPEG-2 format at up to 25fps in 720 X 576 (PAL) mode without loss of image quality
Add great effects, titles, transitions and soundtracks to video footage
Save videos to VideoCD and DVD format
Revolutionary Multimedia Features for Unrivalled Image Quality
VIDEOSHADER™ engine: programmable pixel shaders for video processing acceleration
FULLSTREAM™ technology for superior Internet streaming
High-quality TV encoder for display on PAL/SECAM TV sets supporting up to 1024x768 resolution
DVI encoder for digital flat panel display
Display support: simultaneously connect one VGA or DVI display plus a TV or VCR
Best tool for realtime DV preview/capture?
By Drevin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Feb 2011, 10:28 -
What video card for realtime editing
By MI6 in forum EditingReplies: 0Last Post: 2nd Dec 2010, 04:47 -
Want to get home video pal VHS onto my pc HDD, recomended capture card?
By ha9981 in forum Capturing and VCRReplies: 6Last Post: 26th Mar 2009, 15:34 -
Which card do you recommend for PAL capture to Huffy .avi?
By Chaoji3791 in forum Capturing and VCRReplies: 12Last Post: 13th May 2008, 18:52 -
mpeg 4 realtime bitrates vs multipass mpeg-2 VBR
By miamicanes in forum Capturing and VCRReplies: 5Last Post: 9th Sep 2007, 22:37
