This is related to a previous problem.
How can I tell which codecs I have installed on my system? Is there an easy way to disable/uninstall them from one central location?
I'm wanting to do this to test for incompatibility between codecs.
Thanks!!
-Nate
OH yeah.....this is WinME
I don't know if this shows them all, as I don't know what all I have installed, so don't know if any are missing.
Control Panel> Multimedia> Devices> Video Compression Codecs> Audio Compression Codecs.
This is 98, mind you, so maybe a little diff way to get there in ME. -
fo to analogx.com and go to downloads/audio and get dxman. it will allow you to see and remove any codecs you have on your computer. it is freeware
Thanks for the info....I was able to view all my codecs in settings.
Does anyone know if I can delete any of these or if there are any I don't need?
Or maybe something that conflicts???
try this little program out it will tell you what audio and video codecs are being used
http://www.headbands.com/gspot/ -
BJ_M, thanks.
I've just been ripping my hair out trying to figure out why Sasami will no longer play my SVCD's after uninstalling Elecard andinstalling DirectX, WinDVD, the TMPGEnc Mpeg-2 codec!!
It's all the subject of a very seedy made-for-TV movie!!
I guess I can use WinDVD to play them now.....it's just annoying.....I mean....WHAT THE HECK HAPPENED!!
He he.....gotta smile or I'll go nuts!
-Nate
"Can't sleep.....the clowns will eat me!!"
Help with re-installed XP operating system - Drivers Needed
By jeanpave in forum ComputerReplies: 11Last Post: 26th Jul 2011, 21:51 -
System security 2009 automatically installed
By portlands67 in forum ComputerReplies: 11Last Post: 17th Apr 2010, 22:59 -
No Audio Output in AVI file where Codec is Installed
By yoshijam in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2008, 16:32 -
VD Complain Audio Codec Not Installed
By ks47 in forum Newbie / General discussionsReplies: 2Last Post: 19th Oct 2007, 11:46 -
Application to View Codecs that are Installed on Your System
By JBredensteiner in forum Newbie / General discussionsReplies: 4Last Post: 23rd May 2007, 01:58
