  1. im getting jerky playback on the preview screen in tmpgenc.play fine wmp.i encoded an try on my dvdplayer an it jerk just like the preview on tmpge.i uninstall tmpge an install i even d/l the mpeg2 plugin an reinstall that too still the same.never happen before. need hepl plz.thanx.oh yea only jerk on svcd movie divx an xvid is fine.
    Apr 2002
    The State of Frustration
    Ignore the preview screen output. How does your final TMPGEnc product look?
    Hello.
  3. produt look the same as preview jerky an blurry. any idea
    Apr 2002
    Where did the file come from, and what settings did you use to encode it. In the meantime, do a search under jerky playback and see if you find and ideas you may like to try.
    Hello.
  5. is there another mpeg2 plugin for tmpgenc i can use with.or i hav to use tmpge mpeg2 plugin form the tool page.i think it might be the my mpg2 plugin.maybe im wrong hell im stuck.here s what i was trying to do encode a SVCD MPEG-1 768x576 25fps CBR 1150kbps, Layer-2 44100Hz 192kbps to a XVCD MPEG-1 480x480 29.97fps CBR 2050kbps, Layer-2 44100Hz 128kbps
