when merging and cutting with tmpgenc, which I have used a lot, after upgrading to the new version,I find that it now only encodes 34 secs of the film, any idea how I can change the settings to allow the full and complete edited version to run to the end?
Ness
What version are you using now?
What is your source material?
W.tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Using version 2.59.47.155 of Tmpgenc and source files are mpeg-1's. It looks like they are only encoding the parts I have deleted and not merging the remainder of the film. Depending on where I cut, prior to the merge, it is only the cut bits which are being encoded
Ness
Tmpgenc DVD Author 4 Help Required
By M2DEP in forum Video ConversionReplies: 3Last Post: 17th Apr 2011, 10:05 -
dv cables help required
By rizvi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 18th Mar 2009, 03:05 -
Help Required. Capturing DV to PC
By jeffbhoy in forum Newbie / General discussionsReplies: 10Last Post: 21st Jun 2007, 18:37 -
Software Required
By dbanga in forum ProgrammingReplies: 2Last Post: 15th Jun 2007, 06:47 -
Advise Required
By dbanga in forum EditingReplies: 6Last Post: 4th Jun 2007, 16:57
