I recently turned a 360x480 interlaced NTSC capture into an MPEG-II by using TMPGEnc Plus. I want the resulting file to be playable on TV, so I chose 'Interlaced' under Encode in the Expert options menu. I also used 2-Pass VBR to encode (min: 2000, avg: 6000, max: 8000). When I play the MPEG2 file back in Windows Media Player (using the freedvd codec), the video doesn't seem to be interlaced. It appears to have been de-interlaced using blend mode, but I can't tell if that's the actual file, or if the codec is de-interlacing on the fly.
My Ti4200 has a TV-out connector, so I'm thinking about using that to check the quality of my interlaced file. Is this possible - will playing an interlaced file on a TV-out look like the real thing?
Results 1 to 1 of 1
"The difference between genius and stupidity is that genius has limits." - Albert Einstein
Upscaling 480p vid to 720p without big quality loss.
By MousE0910 in forum Newbie / General discussionsReplies: 11Last Post: 8th Nov 2011, 12:31 -
Mp4 format problem, the vid have a bad quality after i rendered it.
By aisple_aislesz in forum Newbie / General discussionsReplies: 12Last Post: 25th Apr 2011, 10:02 -
Vid quality better in MPC (Windows), than MPlayer (Linux)...
By cwb in forum Software PlayingReplies: 3Last Post: 5th May 2010, 21:01 -
Need Help Encoding Quality Web Vid
By MAtkins in forum Video ConversionReplies: 110Last Post: 8th Mar 2010, 21:59 -
how to upload high quality vid? found 1 upped after february
By bojadada in forum Video Streaming DownloadingReplies: 4Last Post: 30th Oct 2008, 15:42
