I have a AVI file that i want to convert to VCD! The file is 700 MB and is 88 minutes long! When i open the file in TMPGenc it says that the file is 297 minutes, so i have to set the video bitrate to about 100kbit per second for the movie to fit on a disc!!! What am i doing wrong and whats the easiest way to convert this file onto a 700 MB CD in VCD format???
go to kvcd.net and take a look at their templates for TMPGEnc, one of them may be able to help you.Originally Posted by Rillern--
Will -
It sounds like your AVI file is DivX,read this guide:https://www.videohelp.com/tmpgenc.htm
Oh, sorry... Yes its a DivX file! but i downloaded all the codecs and installed them but TMPGEnc still says yhat the movie is 247 minutes!?!?!?! If i open the file in Nero it says that the file will be 800 MB in VCD, maybe i should buy some 800MB disks and burnt on to them!
A 700 MB CDR will in fact hold 800MB in VCD format. Check out the "What is VCD" link in the upper left of this window.Originally Posted by Rillern--
Will -
Sounds like it could have VBR audio which TMPGEnc does not handle well and thus misreports the file length. Open the file in vdub it will probrably warn you of VBR audio. Save the audio as an uncompressed wav file using full processing mode and use this wav file as the source for the audio in TMPGEnc.
AVI to VCD
By Slip Kid in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 01:40 -
avi to vcd
By cornick in forum Video ConversionReplies: 4Last Post: 11th Aug 2008, 21:12 -
AVI to VCD
By northy44 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 6th Dec 2007, 07:27 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
