I have a hardward Mpeg II encoder card, so I can only capture my laserdisc and save it in Mpeg II format. My questions is should I capture it at the highest quality possible which is 10kps and then use Tmpgenc / Mainconcept to reencode it to VBR say 6kps. Or should I directly capture at CBR at 6kps and do not reencode. The reason of CBR is the hardware capture card only support CBR.
Any suggestions would be welcome.
Wilson
Really hard to say, to many variables. Best thing to do is to pick a semi high motion scence and a high color scence, make a 5-10min test capture at max bitrate and re-encode with TMPGenc, AND at 6-8Mbit/s. Burn both to DVDR (can be on same disc) and compare.
Ie give both a try and let us know
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
