I went to burn a file with VCDEasy and it said it is a mpg2.How does one burn
this CD to play on my DVD? Do I need to convert to a different format or
need a programf some type? Thanks for any help.
You have a few options, but first read the Newbie guides to get you up to speed:
1. If the MPEG-2 file is already in SVCD format, VCDEasy can burn it to a CD-(R)W. Click here.
2. If the MPEG-2 file is already in SVCD format, you can change the header on the file and burn it as an SVCD that your player thinks is an VCD, which VCDEasy can burn it to a CD-(R)W. Click here.
3. You can encode your MPEG-2 file to a MPEG-1 VCD format file, and VCDEasy can burn it to a CD-(R)W. Click here.
4. If you own a DVD writer you can encode the file as DVD format file, and use a burner program to make a DVD. Click here.Hello.
mpg2 aspect ratio
By Ogilvy in forum EditingReplies: 2Last Post: 26th Jul 2010, 13:55 -
.tvo to mpg2 problem
By kortmann in forum Video ConversionReplies: 0Last Post: 8th Mar 2010, 15:27 -
Editing MPG2
By danielmak in forum MacReplies: 16Last Post: 17th Feb 2010, 17:28 -
demuxing mpg2
By volam in forum EditingReplies: 1Last Post: 11th Jul 2008, 14:05 -
MPG2 or MPG4???
By JennyBear in forum Newbie / General discussionsReplies: 7Last Post: 1st Aug 2007, 17:33
