Now this is the one --> Premiere6 exported avi can not open in CCE SP2.5. Sony PC5 captured avi with Premiere6 will lopen fine in CCE??? Yes, I had to get MC demo codec which helped open direct captured avi, but exported avi will not work. Both avi show MC_DVD as their codec?
CCE reports "could not find approprate codec for DSVD". Note that this is D S V D, not the trivial dvsd codec message which is solved my main concept free dv codec.
HELP?
You might want to try frameserving the AVI to CCE w/ AviSynth. Can you open the AVI in other programs? How big is the AVI (ie. the 2GB and 4GB limits, although frameserving should fix that).
Yes, I can open the avi in question in TMPGenc and other apps like Vdubb. Its 300M - just a test for now. It appears that Premiere export MS DV is not the same as Premiere capture MS DV??? How do people solve this simple problem - encode with CCE a Premiere produced avi?
No Audio on exported clip from speeded up footage in Premiere.
By kestifer in forum Newbie / General discussionsReplies: 6Last Post: 10th Jun 2012, 18:27 -
dv exported from premiere isn't microsoft dv, it is sony dv; why?
By codemaster in forum EditingReplies: 2Last Post: 31st Dec 2011, 09:28 -
Exported AVI from Premiere pro2 have problem!!!
By yunakokimama in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2008, 21:29 -
DVD exported from Adobe Premiere Elements Help
By Captain Satellite in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2007, 19:09 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 20:47
