Im using this to burn a whole bunch of music videos, bout 45 per DVD. i burnt a test DVD with around 10 videos. I made my menus, 6 clips per menu and this works fine. However, when I burn all 45, after each video plays, my dvd just freezez and I cant do anything but eject the DVD and play it again. Im wondering if this is a bug in ULEAD after so many videos or its my DVD player. I am going to test it another DVD player see what happens, but I was wondering if anyone else has had a similar problem...thanks for any responses
I believe this is a bug in ulead, i tested this DVD on another DVD player and same thing. I tried DVD lab, with the exact same videos, same order, same everything, and it burnt like a charm. If you havent used DVD lab i recommend it...its not that easy to use and first and you have to do most things manually...but you get better results.....
I just did a test in Ulead DVD MovieFactory 2 using the same number of videos.
I don't know the steps you took, but the steps I followed worked.
I used the third menu template at the top of the thumbnails pictured here:
http://www.ulead.com/dmf/samples.htm
Jerry Jones
http://www.jonesgroup.net
Problem with Ulead Videostudio SE DVD and EasyCAP
By Majora in forum Capturing and VCRReplies: 17Last Post: 20th Nov 2011, 03:51 -
Sound problem with Ulead VideoStudio 11
By rogerhacker in forum Newbie / General discussionsReplies: 15Last Post: 16th Jul 2010, 19:41 -
dv/ulead capture, aspect ratio problem
By Statick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 5th Jan 2008, 15:46 -
Ulead VS10 sound problem
By theguy1991 in forum EditingReplies: 1Last Post: 3rd Dec 2007, 19:06 -
Truncation problem when burning DVD using Ulead VideoStudio 8
By goodneit in forum Authoring (DVD)Replies: 3Last Post: 9th Jun 2007, 10:23
