can anyone explain to me the best way to cut an mpeg2 file without loosing sound as i do when using tmpgenc
is their another prog i can try
regards joe
i'm very new to this stuff, but after reading around i tried womble's mpeg2vcr and its excellent!!! you can cut anywhere, (not just i frames) and save with no recompression. the price now has dropped and it sells for $120. as far as losing sound goes, i've never experienced that so i can't tell you whether that will happen or not.
good luck
i believe there is a link in the tools section(?)
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
Simple MPEG2 Cutting/Joining Question
By thefiddler in forum EditingReplies: 4Last Post: 21st Dec 2009, 15:39 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 08:45 -
[solved] Major MPEG2 Cutting issues. Looking for program that will work.
By ShadowBlink in forum EditingReplies: 17Last Post: 17th May 2007, 19:55
