I use it to image the Video_Ts AND AUDIO_TS folders but then it stops at 99.89% and saying the drive ran out of space but the problem is the drive is stil with over 100 gigs free ? What can I do.. thanks for telling me about Imgtool but still I cannot get it to work. I am using Win2k and with a lot of memory and drives.. they are mainly a wedding vide I capture but the Canopus AD 1000 unit. Thanks for guiding me.
Are you trying to create an image file bigger than 4.1GB on a FAT32 Disk?
I just fought with the same problem. Once I switched the destination of the image to an NTFS disk, it worked fine.
Greg
how mpegts works
By alntke in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2011, 11:36 -
Device Capture - USB, Works With PAL / NTSC, Works with VirtualDub/VCR
By Drazick in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2010, 18:27 -
Tmpgenc Authoring works
By quxote in forum Authoring (DVD)Replies: 1Last Post: 27th Nov 2009, 15:56 -
DVD Shrink to VOB,IFO, BUP and then IMGtool to ISO, bigger than 7GB
By opieandy in forum DVD RippingReplies: 3Last Post: 28th Sep 2007, 15:04 -
ImgTool Files Too Large
By opieandy in forum Authoring (DVD)Replies: 4Last Post: 27th Sep 2007, 21:08
