What is the cheapest \ simplest way of converting componment video to s-video?
I have a component output that I want to get into my ACDV-100 unit
I need the same conversion. I found this http://www.videocapturecard.com/comp2svideo.html, but they seem to have stopped making them (and the quality appears to have been sub-par anyway).
Xesdeeni -
I had bought one about 6 mon ago. Radio shack $25.
Don't give in to DVD2ONE, that leads to the dark side. -
Do you have a model no for that converter from radio shack? I can not find it online.
Thanks -
do you have a s-video out on the thing you want to plug into your acdv. You don't get any better quality if you convert from componet to s-video rather than s-video to s-video. You might even get worse if your converter isn't that good.
Fry's had one for $4.95. It works both ways, svideo to composite, and composite to svideo and its small about 1 inch in size.
Folks. We're talking about converting COMPONENT to s-video, not COMPOSITE.
Component: Three wires = Y (luminance), U (Pb; chrominance), V (Pr; chrominance)
S-video: Two wires = Y (luminance), C (U and V combined chrominance)
Composite: One wire = luminace and chrominance combined
Xesdeeni -
There is some confusion here
I want to convert COMPONENT to S-video
Component not composite
Component has 3 cables RED BLUE and GREEN (I think thjose are the colors) this is what I want to convert to S-video
Composite video however is a single yellow cable
Intel GMA HD/Core i3 - VGA has TV-out/S-video-out/component-video-out?
By Morality124 in forum Media Center PC / MediaCentersReplies: 5Last Post: 9th Jan 2011, 00:44 -
Will Component Video / S-Video Adapter Help Me?
By waldodiodio in forum Capturing and VCRReplies: 1Last Post: 4th Dec 2010, 11:56 -
RCA composite video on Wii but component video and VGA inputs on tv
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2010, 21:48 -
Compatibility of composite video output VCR with component video input TV
By boshu22 in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2009, 22:46
