Hello.
It's been 2 weeks since I started to try to convert an .avi, over 750,000kb in size, to a useable format for authoring a DVD.![]()
I tried to use Ulead Movie Factory 2 to make the conversion and burn to a DVD. I ended up with a DVD that played fine, but midway through it, I started to get the audio from the first half of the movie! There weren't two tracks, one on top the other, the track that should have been there was gone, replaced by the audio from the first half of the video. Luckily I used a DVDRW so I lost nothing but time.
What caused this?![]()
Then I tried to use TMPGenc to make an mpeg-2 file from the DivX .avi.. this turned into an all night affair. IN the morning I was greeted with a 15GB mpeg-2 that I couldn't play, let alone use to make a DVD!!
If it was YOUR movie file and you wanted to convert it to a DVD or a pair of SVCD's how would you do it?![]()
Thank heavens for this page and its forum, otherwise I would really really be lost.
Thanks in advance to all who reply!![]()
J T
PS: I have a number of .avis that have accumulated over the years, I 'd love to have them on DVD. But it seems this is almost an impossibility given the current success levle I have been experiencing.
Results 1 to 1 of 1
Need to combine 2 DVDs, DVD#1 need second half only and DVD#2 new audio
By ssalim in forum Authoring (DVD)Replies: 1Last Post: 30th Jan 2009, 12:07 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 14:16 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 09:35 -
Half the disk is formatted PAL, the other half NTSC...Doable or not???
By AlecWest in forum Authoring (DVD)Replies: 15Last Post: 16th Oct 2007, 09:31 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 11:55
