Hi all
Is it possible to create a blank .mpv file (static black background) or to "convert" a static image (jpeg, bmp,...) to .mpv?
Thanks in advance.![]()
It shouldn't be any different than any other MPEG file -- I could create one in a couple of seconds with Premiere by just laying down a black slide and encoding it out.
Are you saying how to create it without video editing tools?"Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
Yes.Originally Posted by mkelley
P.S: can softwares like Adobe Premiere demux-remux vob files?
No, Adobe isn't a demux/remuxer -- although tools like VOBedit can do all this stuff easily.
Here's a link to creating VOBs without Premiere (but you do need TMPGEnc Plus, so you'll have to spend money somewhere):
http://www.dvdfab.com/index_e.html
Note that it talks about creating lots of VOBs (and also using them in DVDFab) but I think you'll get the general idea."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
Thanks for the info, mkelley, I will have a look.
This is mainly for experimenting purposes, so I didn't intend to spend any cash though.
Just take any static image and load it as the video source in TMPGenc. Set the output to video only and encode.
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 07:17 -
How to remove giant blank space at end of movie file?
By Quetzecotyl in forum EditingReplies: 2Last Post: 30th Jan 2009, 18:55 -
How to create subtitle file from transcript text file
By amagrace in forum SubtitleReplies: 7Last Post: 8th May 2008, 12:44 -
Blank video in avi file
By skaleton in forum EditingReplies: 9Last Post: 16th Apr 2008, 17:42 -
Belight creates blank file?
By snadge in forum Newbie / General discussionsReplies: 36Last Post: 17th Jan 2008, 14:40
