  1. History
    Version 1.2.1 BETA download dvdlabup121.exe (2.1 MB) - you need to have installed at least full 1.1 version.
    - Optional Frame-Indexing movies and therefore ability to enter chapters by frame number with better accuracy.
    - Option to Follow Link during Simulation. If enabled, when you click on button during simulation you will get to the linked item etc...
    - Multiple selections of Menu Objects and operations: move, resize, set same size, align, place to grid, change color, drop shadow
    - More Drag&Drop helpers: When you drag a Movie from Project to empty place on menu a thumbnail and link will be automatically created (Holding Shift will create just a text). If you drag a Menu a Text with link will be added.
    - Change: before Movie could return to first 10 menus only, now this is extended (on account of remembering selection of last button), Force select button now set to 1 by default
    -DVD verification of burned discs.
    -LPCM fix for some wav
    -some changes in relaxed multiplexing
    http://www.mediachance.com/dvdlab/history.html
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    joepic -
    not to quibble, but is there something in this post that's significantly different from your previous one?
    https://www.videohelp.com/forum/viewtopic.php?t=163971
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    the last d/l version was 1.2 - this is 1.2.1 , though that may not have been completly clear in his prev. post ...
  4. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    fair enough
    - housepig
    Housepig Records
    out now:
