Hi, all,
I have a client that wants a DVD with an additional Spanish language track. Is this possible with DVDLab?
At the present, DVD-Lab does not support dual language. Here is what the author says:Originally Posted by Rickster
What about multiple audio channels?
This is quite complicated so first I'd like to see how the application goes and then if it gets attention I am planning to put all effort to multiple audio channels. Probably PRO version with a little higher price will be released with multiple audio but current users will be able to register it just for the difference in price.--
Will -
Rickster,
Like willy_annand says currently DVDlab does not support multiple audio streams but it is possible to do it with a little work around.
1. Using Ifoedit I create my VOB files with mulitple audio streams.
2. bring these into DvdLab (Import them as is),
3. create menus etc, compile project to harddrive and force all audio streams.
4. once the project is compiled, there is an option within Dvdlab to re-edit the vobs files to properly identify the audio tracks.
you will be able to access the second audio track via the remote control audio button. you can test it with powerdvd before burning.
* all audio streams must be in the same format
iTunes and multiple audio streams
By TheNomad in forum Video ConversionReplies: 7Last Post: 28th Sep 2010, 16:18 -
Multiple Audio Streams (Avi)
By nycboriqua in forum EditingReplies: 5Last Post: 26th Sep 2010, 18:42 -
VOB2MPG Multiple Audio Streams
By secretsubscriber in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 4th Jun 2009, 11:04 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 19:44 -
By Tobberian in forum AudioReplies: 2Last Post: 14th Jul 2007, 13:54
