I want to fit a movie of 115 minutes on 1 VCD (dont ask :P) but with the normal presets ffmpegX gives a red bitrate. lowering the sound to 128 bitrate still keeps in the red. So if I lower the resolution a little bit, I am able to get it in the green zonebut does this improve the quality on my tv compared the the red bitrate but larger resolution mpeg?
" Military intelligence is a contradiction in term."
- Groucho Marx
A VCD can only use standard image size for playback on a DVD player. However if your source is a NTSC VOB, probably setting framerate to NTSC FILM will reduce enough the number of images per second to almost go again to a green bitrate. Also if your DVD player accepts non standard VCD in VBR mode, you can disable constant bitrate encoding and use a higher bitrate - the final size will probably be lower than the calculator forecast.
Fairuse wizard "Resolution/AR" question!
By UnD3R0aTh in forum DVD RippingReplies: 6Last Post: 18th Mar 2010, 06:14 -
Best bitrate/resolution etc for watching avi on a 32/37" LCD TV
By splogo in forum DVD RippingReplies: 4Last Post: 18th Apr 2009, 07:41 -
philips dvp5992 displays "Video Resolution not Supported"
By mike69 in forum DVD & Blu-ray PlayersReplies: 20Last Post: 30th Dec 2008, 09:17 -
VHS capture - "flickering" red
By pfredd in forum RestorationReplies: 12Last Post: 19th Nov 2008, 21:24 -
Clips From the "New" Red 4K Res Camera
By Soopafresh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 1st Nov 2007, 12:47
