I have got a problem with my sony 510 writer and it seems that it is going to need to be sent back. If i do end uo having to have another drive other than the sony is there any other worth getting or is the sony the best writer at the moment for writing not reliablity?
PaulDiston
from what i have read, the nec 1300a isnt a bad drive at all. i am getting the msi which is just a re badged nec. most of the problems with the nec have been dickhead user error. -
NEC 1300A for 193.00 and do the same and more when it comes with DVD compatability.
LG and IOmega both have a model coming that does DVD-+R/RW and DVD-RAM. Pioneer also will support DVD-+R/RW with their A06 model coming soon.
Check out www.cdfreaks.com for news and anouncements (sorry, no tests yet). -
CCL in Bradford strongly recommended the Freecom FX-50 external writer as an alternative. Can't find any reviews or Forums information/postings relating to this unit though. I might go the NEC1300A route and abandon the firewire capability
I think the freecom only writes to DVD+. I would much rather be able to write to DVD- if a can't get a dual format writer.
Paul -
No, the Freecom FX-50 is both '+' and '-' See: http://www.freecom.com/objects/00002195.pdf
This makes it all the more stranger given the well publicised supply problems of the Sony unit. If, on paper, the Freecom is equally specced you would expect them to have sold more. -
another problem with the freecom is that it needs USB 2 or firewire connections. I have neither. Dam sony why do they do this to us.
Vertical lines with Pinnacle Studio 14/510 USB card
By karebo in forum Capturing and VCRReplies: 0Last Post: 11th Dec 2011, 16:54 -
Encoding Video for a D-Link DSM-510 MEDIA PLAYER
By loughary in forum Video ConversionReplies: 1Last Post: 9th Oct 2009, 22:37 -
Pioneer 510-H Won't Power Up
By groberson in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st May 2009, 01:11 -
Converting Video on a Harmon Kardon GPS 510
By markula in forum Video ConversionReplies: 0Last Post: 13th Jul 2008, 21:13 -
Sony RDR HX 510 and DVP NS 305
By SearchQuality in forum MediaReplies: 10Last Post: 16th Nov 2007, 11:41
