I have a video in 640x320, used virtuadub to crop it some arbitrary size that I thought was fit (sumthin like 607x289) and Divx 5.05 said it could not save it... divx 3.11alpha saved it, but it was slanted video (eg. on a 45 degree angle) and in black and white with lines thru it... can I assume that divx compression needs to be in a 4:3 resolution?
eg. below is a fence with boards that should be vertical... instead they are slanted and a blank line cuts across at a 45 degree angle
it can be any resolution you want but the dimentions must be a multiple of 8 ( I think....)...i.e. you can have 640 or 648 but not 645.
The ratio can be whatever.....16:9, 4:3, 47:2 (although the last one might look weird, it is perfectally legal)"Weekends don't count unless you spend them doing something completely pointless."
Bartman 8) -
uh, you're confusing me... is the last one the only exception to the rule of 8?
er...there are two things to consider...the ratio and the resolution....the ratio can be whatever you want...
take a divx at 640x480. This is a 4:3 ratio which means that the width is 4 units and the height is 3 units. In this case the width is 640 (4*160) and the height is 480 (3*160). Our 'unit' in this case is 160 pixels.
47:2 is an extreme example but if we use the same unit as above (160) then we get a width:height ratio of (47*160) : (2*160) which translates as a resolution of 7520x320.
Ratio and Resolution.......when I asked hawker in Thailand "Is this a real Stussy shirt" he said to me "Same same...but different""Weekends don't count unless you spend them doing something completely pointless."
Bartman 8)
Quick compression size question.
By capman21 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2008, 20:35 -
Arbitrary AC3 Re-Encoding by DVDStyler
By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 6th Sep 2008, 15:57 -
Using ffmpeg to mux an arbitrary number of streams from multiple files
By punmaster in forum Video ConversionReplies: 5Last Post: 4th Aug 2008, 00:14 -
is there a way to save at a Smaller size avi
By gilnan in forum EditingReplies: 3Last Post: 7th Apr 2008, 15:37 -
calculate the size to save
By Cazz in forum EditingReplies: 7Last Post: 11th Jan 2008, 06:05
