I have some .m2v video files + corresponding audio files in AC3 format.
I'm trying to burn them in DVD but ULead DVD Movie Factory2 doesn't recognise the. If I convert the AC3 to MP2 works just fine but I want to keep the sound in AC3 format. Any way to do that?? Or maybe I need to buy some other authoring software which does recognise the AC3 files???
Not that this helps you but I have completely given up on any ULead products as they are either broken or are missing some important feature.
I believe NeoDVD will handle AC3 files.
http://www.mediostream.com/products/neodvdplus/index.html -
There is a "way" around this. If you multiplex your M2V and AC-3 files into a single MPEG file then you CAN import that MPEG file into MF2Originally Posted by tonyzz
Now you will get an error message (at least the first time you do it) but don't worry ... as long as you don't EDIT in MF2 and only use it to create menus and custom chapter points etc. then the file will be authored correctly. The AC-3 sound will be passed through without problems. Just remember that you will NOT have any audio when doing a preview in MF2
One last thing ... to get this to work correctly you NEED to check the option that says something like this: DO NOT CONVERT DVD COMPLIANT FILES
It's that easy
- John "FulciLives" Coleman
P.S.
I use TMPGEnc Plus to multiplex the M2V and AC-3 into a single MPEG file"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
NeoDVD will re-encode your input even it if is DVD compliant to begin with. Obviously that is a BAD thing. NeoDVD is basically for newbies or those too lazy to use something like TMPGEnc or CCEOriginally Posted by Bob W
Ulead DVD Factory 6 File Format Mismatch
By nala310 in forum Authoring (DVD)Replies: 1Last Post: 17th Jan 2010, 04:20 -
AC3 doesn't work after format
By Xavier in forum AudioReplies: 7Last Post: 26th Feb 2009, 19:27 -
Trying to Convert avi. (Dvix) with AC3 audio file to DVD Format
By carlos305 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 09:54 -
Womble doesn't recognise avi audio from my Samsung Digimax
By keveen in forum AudioReplies: 2Last Post: 26th Jul 2007, 17:24 -
Ulead DVD MovieFactory 6 - Doesn't recognize DVD
By urlilgurl017 in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2007, 13:52
