HI all!
I'm using the panasonic mpg1 enoder ...it always worked fine, now all of sudden, it won't show me the frame size anynore. I'll load my file and all it shows it's a big 0 where the frame size is suppose to be. when I try to encode it gives me the error message " A ERrror acured Pw has to close now!
I tried to reinstall the encoder but still the same!
Any suggestion??
Thanks tia
Tanja
