Im trying to split a 1600mb MPEG that i have after i did a dvd2svcd conversion and im getting errors as seen below maybe someone can tell me how i can fix this so i can split the file and not have sycn errors
Multiplexing: video and one audio stream
program stream type: SVCD with pulldown auto-detection
video file: c:\documents and settings\PIMP\my documents\=m=o=v=i=e=s=\charlies angels dvd2svcd.m2v
audio 1 file: c:\documents and settings\PIMP\my documents\=m=o=v=i=e=s=\charlies angels dvd2svcd.mp2
program file: temp.mpg
Multiplexing video and audio:
Scanning video stream for a sequence header and pulldown type ...
no pulldown detected ...
Scanning video stream for pictures ...
Found 135622 picture headers.
Video stream information
Stream length : 1530622449
Total time (seconds) : 4525
Sequence start : 15727
Sequence end : 0
No. Pictures : 135622
No. Groups : 15727
No. I Frames : 15727 avg. size 32245 bytes
No. P Frames : 60249 avg. size 13143 bytes
No. B Frames : 59646 avg. size 3883 bytes
No. D Frames : 0 avg. size 0 bytes
Horizontal size : 480
Vertical size : 480
Aspect ratio : 0.6735
Picture rate : 29.970 frames/sec
Bit rate : 315000 bytes/sec (2520000 bits/sec)
Computed avg rate : 338750 bytes/sec (2710000 bits/sec)
Computed max rate : 437400 bytes/sec (3499200 bits/sec)
Vbv buffer size : 114688 bytes
CSPF : 0
Scanning audio stream for access units information
Found 216513 audio frame headers.
MPEG audio stream information
Stream length : 158363752
Syncwords : 216513
Frames : 123722 size 731 bytes
Frames : 92791 size 732 bytes
Layer : 2
CRC checksums : yes
Bit rate : 28000 bytes/sec (224 kbit/sec)
Frequency : 44.1 kHz
Mode : 0 stereo
Mode extension : 0
Copyright bit : 0 no copyright
Original/Copy : 0 copy
Emphasis : 0 none
NOTE: Mux rate may be too low for data rate, watch for PTS/DTS underflows.
Multiplexing information
Video stream data rate : 437400 bytes/sec (3499200 bits/sec)
Audio stream 1 data rate : 28000 bytes/sec (224000 bits/sec)
Total data rate : 348600 bytes/sec (2788800 bits/sec)
Multiplexing file temp00.mpg
video PTS (5351.83ms) underflow at pack 590 by 1.50ms
video DTS (5618.77ms) underflow at pack 638 by 54.57ms
video PTS (5652.13ms) underflow at pack 644 by 61.20ms
video DTS (5685.50ms) underflow at pack 648 by 54.50ms
video PTS (5718.87ms) underflow at pack 654 by 61.13ms
video DTS (5752.23ms) underflow at pack 657 by 47.77ms
video PTS (5785.60ms) underflow at pack 663 by 54.40ms
video DTS (5818.97ms) underflow at pack 665 by 34.37ms
video PTS (5852.33ms) underflow at pack 673 by 54.33ms
video DTS (5885.70ms) underflow at pack 677 by 47.63ms
There was alot more video DTS (blah blah blah) underflow at pack blah blah by blah blah.blahms it did throughout the whole time so if anyone can see whats wrong maybe they can help
Set the "Forced mux rate" to 0 in the program stream settings of bbMpeg.
Your max birtrate goes beyond the limit for SVCD. SVCD has a max mux rate of 2788800 bits/sec, your video stream alone is peaking at 3499200 bits/sec.NOTE: Mux rate may be too low for data rate, watch for PTS/DTS underflows.
Either always mux with a forced mux rate of zero, or correct your bitrate settings to stay with in the SVCD specs.
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 22nd Apr 2011, 23:59 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 05:45 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
