  1. Member pharries's Avatar
    Nov 2002
    Anyone know how I would convert the output fromn a broadcast 8 pin monitor cable to S-video?
    thanks
  2. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    If memory serves, they only output composite video. Not S. And what connection does what I can't remember either.
    video in
    audio in
    video out
    audio out
    Audio is unbalanced and single channel.
    Audio is normally controlled by the audio monitor switch on the deck (ch1 or ch2 or mix).
    If you want Y/C video, you will have to see if it has a connector labled "DUB". But you are not done there. The DUB out uses a higher band for the sub-carrier and so it will not likely work with your consumer S-video (Y/C). The DUB s/c was normally something like 4.54 Mhz or maybe 4.83 Mhz instead of the lower and standard NTSC video of 3.58 Mhz.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  3. Member holistic's Avatar
    May 2001
    here & there
    S-Video splits the chrominance and luminance signals at a guess, looking at the link here, http://www.alteeve.com/~lance/Hack.html I would join the Y signals to themselves and the C signals to themselves.
    (assuming of course this is how you machine is wired !)
    Hope this helped somewhat.
    some links:
    http://wired.hard.ru/pin_Video.shtml
  4. Member pharries's Avatar
    Nov 2002
    OK found it this is not compatable with component video it is single channel composite in and out, audio in and out
