Is the disk speed a concern for a standalone?![]()
I have a Philips 985 dvd Recorder, which uses DVD+R/+RW discs.
I have successfully recorded on a Maxell DVD+RW.
As for a Dvd +R disk, I tried a Verbatim DatalifePlus which says it burns at 2.4x-And it won't record?
Any help would be great. Thanks.
you should prolly experiment with your particular player.
personally, i've always burnt at lower than max speed just to be sure it's compatible with as many players as possible. -
Well, I've tried burning on another Verbatim disk -but they still don't work a message saying "1 Post Error" keeps coming up along with "Disk Warning" and I can't find anywhere to change recording speeds on this standalone player.
POST usually stands for Power On Self Test. If that's failed, I'd say it was a recorder problem... and it's not going to get better on its own, I'm afraid.
If it's in warranty you might want to get it looked at. If not, it's probably going to need the attention of an engineer armed with a service manual.
Raid 5 disk speed performance question
By zzyzzx in forum ComputerReplies: 3Last Post: 18th Feb 2011, 14:30 -
Vegas concern
By Mitterhouse in forum Authoring (Blu-ray)Replies: 2Last Post: 27th Oct 2010, 09:07 -
At what point do we draw the line between quality concern and paranoia?
By Anonymous4 in forum Newbie / General discussionsReplies: 5Last Post: 1st Sep 2008, 00:49 -
1st order of TYGO2 -- cause for concern ?
By Seeker47 in forum MediaReplies: 1Last Post: 21st Jun 2007, 17:13
