OK, is this a silly question ?
I know the Proccessor makes loads of differance but , does the Graphics card make any differance to speed and quality when capturing VCD's in TmpEnc ?
& if so which is the best card to go for (I already have GForce II MX400)
The capure card, processor, amount of RAM and HD speed are all deciding factors in the capture quality. The minimum specs should be 128RAM a 500MHz CPU and an ATA66 drive. A straight graphics card won't make any difference in the conversion quality since at this point it all depends on the quality of the capture source, the conversion program and the processor.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
