Hi,
When I use Tmpgenc to convert a SVCD or DVD in the output video there are small squares ( 9 small squares that form a bigger square) that appears on the video. These squares jump around the screen starting near the top left corner.
Is this some kind of watermark created by Tmpgenc.
Sounds weird but it is hard to describe these jumping squares.
thanks.
It's from the Elecard mpeg2 codec, demo version. If you remove it and install Powerdvd or other software DVD player it will install an mpeg2 codec as part of the package.
"Art is making something out of nothing and selling it." - Frank Zappa -
BINGO! I had the exact same problem. I uninstalled Elecard and installed PowerDVD.......NO MORE JUMPING BOX!!!
Good luck! -
But, is there a way to tell TMPGEnc not to use Elecard while it is still in system? Namely ProgDVB requires Elecard drivers.
Mpcstar pixelation problems picture becomes clumped squares
By kakashi9401 in forum Software PlayingReplies: 0Last Post: 15th Jul 2010, 13:52 -
why do cds or dvds stick or show squares or slow down when playing?
By wan2no in forum Newbie / General discussionsReplies: 12Last Post: 4th Apr 2008, 21:09 -
A font with only squares, how to create?
By sybariten in forum ComputerReplies: 3Last Post: 21st Feb 2008, 15:38 -
Squares Appear When Playing Online Games - Resolved
By HacktheHacker in forum Software PlayingReplies: 6Last Post: 20th Jan 2008, 16:07 -
3d Games Cause Large Squares on Screen - SOLVED!
By HacktheHacker in forum ComputerReplies: 11Last Post: 29th Jun 2007, 19:59
