What is the difference between Nero and Nero Express?
I got Nero Express with my CDRW drive. When I install first time I am getting nero burning rom but after exiting from the application I dont even see the nero burning rom option on my desktop.
There is no option to go back to nero from nero express (but the documentation says so).
From nero express I am not able to select "nonstandard CD" option while creating VCD.
Someone please help me.
Thanks and Regards
Dominic
I haven't used Express much, but I think it's just sort of a template or wizzard type thing to help you through the process. I just use burning rom, so I could be mistaken. If you are actually looking at Nero Express you should have a box to close express and go back to Nero burning rom.
Nero Vision Express on the other hand is sort of a different program. You can supposedly capture video with it (never shows I have a capture card for me though) and drag your already captured files into it and it creates your DVD files for you. Probably will burn the disk also. I don't like it so I don't use it, but that's about basics I beleave. It seems to be it's own program, so it does not have and option to go back to nero burning rom that I know of.
Both should show in your start/programs menu if you have both. Niether is on the desktop, unless you put it there. Or I selected to not put it there on mine? Win 2k pro.
Ahead Nero (burning rom) and Nero Vision. I think it's confusing and dumb of them to have two dififferent things called Nero Express doing different stuff, but both programs have a nero express! -
Originally Posted by overloaded_ide
The documentation says press "Go Nero" button to go back to "Nero Burning Rom". But there is a button NERO and if I press it shows www.nero.com. (See the image)
Regards
Dominic -
It might be the type oem you got then? If your disk says nero express, maybe you didn't actually get nero burning rom with it?
I have the exact screen you posted. If I click the nero button I get a pop up warning type box I am closing express and about to be switched to the more powerful nero. Then click ok and I am in regular Nero.
In start/programs I have Ahead Nero and in that I have a choice of Nero burning rom or Nero Express. You don't have a choice, just express?
Also when I piont o the menu for nero buroning rom I have several other things to choose from, like cover designer and others.
What drive did you get that oem with? When I buy lite-ons I think I got both. Mine have had the registrations codes entered plus I added other stuff since then too. But I am pretty sure when I installed my Nero stuff I had both, but for sure I have always had the regular nero.
Afraid I can't help ya much on this, maybe someone else will be able to.
I'd check the docs and box, then e-mail whoever made the drive and see if your suposed to have both or just express in the version you got.
If you check the nero site you might be able to download a copy of nero, then see if your key works. My OEMs work fully, but only on the drive they came with, found that out when I had 2 burners installed. I could only use the nero with the lite-on it came with. SO maybe you can unlock a nero for just your burner with that key?? I only ever had one key with an oem nero, but both install. -
Thank you for your response.
Regards
Dominic -
I use NERO EXPRESS all the time to burn my DVD's. Despite what others may say I think this is a great program to burn DVD's with.
Good Luck.
SLICK RICKOriginally Posted by lordsmurf -
Let us know what cendyne says about it. I never bought one of those drives yet, but I might sometime for friends or whatever and would like to know too.
Curruntly I try to get lite-ons for cd burners, and haven't decided on anything specific yet for DVD burners. I like my toshiba so far.
But I buy what people want installed too, so I may be doing cendynes sometime. -
overloaded_ide
I spoke to Cendyne CSR and after verifying few things he gave a new serial number for Nero and now nero works exactly like "yours".
Thank You overloaded_ide
Regards
Dominic
nero 11 express
By tarzan54 in forum Authoring (Blu-ray)Replies: 12Last Post: 9th Feb 2012, 23:28 -
Nero Express stopped working - why?
By TexAsh in forum Newbie / General discussionsReplies: 2Last Post: 9th Dec 2010, 14:28 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
better tha nero vision express
By cesarin in forum Authoring (DVD)Replies: 1Last Post: 24th Jun 2007, 13:34 -
Nero Express stalls out
By tommyboy9495 in forum Newbie / General discussionsReplies: 1Last Post: 7th Jun 2007, 14:03
