  1. Do I need a DVD burner if I want to play SVCD's on a DVD player?
    -Thanks in advance
    Oct 2002
    Huntsville, Ontario, Cana
    -Thanks in advance
    No, SVCDs are burned onto CD-Rs, so a CD Burner would be fine.
    Will
  3. I don't think so. I recall making some SVCD discs using my CD burner and then I used my DVD player and drive to play them back.
    Apr 2002
    The State of Frustration
    Bob W, the answer is you can use a CD-RW or a DVD-+RW to make SVCDs that will play on a DVD player provided the player supports CD-Rs
    Hello.
