I use a Winfast TV2000 dlx card for vhs video capturing. I understand I have to install third-party drivers for this card to capture higher res. video (higher then 320x240) in VirtualDub ... although I'm not sure why.
Is the video upsampled by the software when capturing at higher resolutions?
Also, when capturing from VHS, will higher rez capturing (640x480+) improve the video quality?
thanks!
hp.
well, with the winfast software that came with the card you should be able to cap at 720x576 as maximum res i think.
640x480 is a good resolution for tv captures. the quality is improved.
Video for natural resource monitoring - technical questions
By pdowty in forum Newbie / General discussionsReplies: 4Last Post: 12th Mar 2012, 15:10 -
Winfast tv 2000 xp
By Haopengyou in forum Capturing and VCRReplies: 5Last Post: 21st Jun 2010, 13:38 -
Winfast 2000 XP input jack is a PS/2?
By jabberdau in forum Capturing and VCRReplies: 7Last Post: 18th Nov 2009, 15:46 -
Windows 2000 Questions
By dafoe in forum ComputerReplies: 2Last Post: 21st Dec 2007, 17:31 -
Are my specs high enough for 720p capture as x264? + Many other questions!!
By htpcnewbie in forum Media Center PC / MediaCentersReplies: 8Last Post: 17th Oct 2007, 08:22
