OK I have 5 VOB Files and I need to know how I can make these into an SVCD. If you have any help please email me at h_fan_X@hotmail.com because I have problems logging in here.
Thanks!
Then you're screwed
Mabye you should look to the left under 'DVD rip' for guides on backing up DVDs to SVCDs (There are several). Or check out DVD2SVCD at http://www.doom9.org (for DVD2SVCD to work you'll need a seperate encoder either TMPGenc or CCE). -
I used DVD2SVCD but during the process it came up with some error so I'm trying to use the files that I saved.Originally Posted by Vejita-sama
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 07:31 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
How are ifo files created with only vob files?
By Han Solo1 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2008, 13:07 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15
