can any one help me to cut a mpeg file in tmpgenc ihave tried to cut but the resulting file has no audio any ideas please regards joe
If you are using Merge & Cut, try using the Source Range instead, or vice versa.
Hello. -
I don't know if its a bug or what, but yeah, TMPG looses the sound when you Merge&Cut
The solution, is take your original MPEG2 and Demux, then take the audio file and cut it with some other program (be careful that you cut it at EXACTLY the same place you did the MPEG2 otherwise it'll be out of sync), the Mux it back with the MPEG2 file that you cut.
Hope this helps. -
I use the Merge and Cut feature of TMPGEnc all the time and it works great. I know this does not help you, but I do not think it is a bug. Let me see if I can figure it out.
that's funny, it's never done that on any of my files.I don't know if its a bug or what, but yeah, TMPG looses the sound when you Merge&Cut- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
Simple MPEG2 Cutting/Joining Question
By thefiddler in forum EditingReplies: 4Last Post: 21st Dec 2009, 15:39 -
[solved] Major MPEG2 Cutting issues. Looking for program that will work.
By ShadowBlink in forum EditingReplies: 17Last Post: 17th May 2007, 19:55
