Hi, I've converted few files from VHS to svcd using canopus procoder.
The converted files plays perfectly on computer (either from HD or burned CD-R) but audio is out of sync when played on TV, any suggestions?
I'm using nero software for burning and power dvd for pc playback,thanks. DVD model is Toshiba SD-1300
most likely your audio is recorded at a variable bitrate instead of a constant bitrate
Did you look up your player in the DVD Players section? You should, it has problems with some SVCD's.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks! didn't realise it, I just saw the specs in this forum showing it supproted both svcd and xvcd but did not read the comments.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
