The short story:
-Started with a 7.5 GB movie (DVD format, i.e. VIDEO_TS) and wanted to shirnk it to 4GB (again DVD format).
-Selected the quick preset in FFmpegX and the proper bitrate
-15 hours later, it had created the .mpv file, .mpa file and merged them into a .mpg file (which plays in mplayer)
-Then it created the directory structure for the resulting DVD
-then the shell exited with a seg fault, I tried resubmitting the command but it failed again in the same fashion. I tried using the .mpg file as input to FFmpegX, but it attempted to create the .mpv and .mpa files all over again. I did not want to wait 15 hours.
Here is the command that failed:
sh: line 1: 1403 Segmentation fault ./ifogen -A mp2 -o VTS /Users/admin/Movies/smallMovie/test.mpg >/Users/admin/Movies/smallMovie/test.DVD/VIDEO_TS/VTS_01_0.IFO
Please let me know what I can do to help in debugging this problem.
anonymousGuest
Rear projection HD tv picture fault
By Stedalton in forum DVB / IPTVReplies: 0Last Post: 22nd Jun 2010, 13:16 -
Car radio fault
By didikai in forum Off topicReplies: 2Last Post: 26th Oct 2008, 17:17 -
Segmentation fault while executing dvdauthor
By mmasroorali in forum Authoring (DVD)Replies: 3Last Post: 17th Oct 2008, 19:33 -
No luck with ffmpegX - mencoder segmentation fault.
By jonnymorris in forum MacReplies: 4Last Post: 2nd Mar 2008, 14:07 -
fault on toshiba rd-xs24
By superray in forum DVD & Blu-ray RecordersReplies: 0Last Post: 20th Dec 2007, 07:31
