Hi,
I paid for streaming video over the internet. I used microsoft media player, which buffers the streaming video and plays it back. How do I capture this video to a mpeg file? What application do I used.
Any help is greatly appreciated.
Thanks,
Capt Rage
ASF Recorder would definitely be the one to use. Just do a search for it and you'll get lots of results.
How do I get the ASF recorder to work. In the readme file, it state to right-click mouse button and get the url. I tried that on the ms media player ver 7.0 and nothing happens. Can someone give me a starting point instruction. As you can guess, I am new at this.
Thanks,
Capt Rage -
Get StreamBox VCR and the patch available here: (just sign up, it takes one minute and you can use bogus info)
http://groups.yahoo.com/group/buzzinhornetz2001
And also get URLSnooper and ASFRecorder (all available there)
Then read these instructions and post and questions at this site
INSTRUCTIONS:
http://pub25.ezboard.com/fstreemeboxvcrfrm1.showMessage?topicID=801.topic
forum:
Good Luck
NOTE: StreamBoxVCR probably won't work with password protected streams!
...I'm a stream master! -
Right click on the embedded video window and select properties. In that tab there should be an address with either http or mms,. Copy the entire address. add a / and add the file name which also appears on the tab. Don't forget to add the .asx or .asf extension or it will give you a 404 File not Found error. Put the whole thing in the File --> Get URL and press the record button and it should work.
Hi again,
I have 1 last question. After I save the .asf file to my harddrive, which is the best application to convert it to avi format? I noticed that the .asf streaming video is not the highest quality. When I convert it over to mpeg or avi, can I get a better quality (VCD quality)?
Thanks for the advice.
Its been a great help,
Capt. Rage -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Do I have o join that Yahoo group in order to download the files?
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 23:42 -
Capturing SWF Stream, Results in Taunting Server Admin Video
By smartwhois in forum Video Streaming DownloadingReplies: 1Last Post: 27th Jun 2008, 12:31 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27 -
Capturing an image from a live stream video (MMS protocol)
By ali1977 in forum ProgrammingReplies: 0Last Post: 29th Nov 2007, 02:43 -
Capturing web stream
By peter762033 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 12:47
