hi there
i capture TV PAL 720x576 videos
i am using Gknot to do the encoding...
when compressing the CAP for PC...
what is the right aspect ratio i should use when resizing the video ?
should i keep it as it is when captured 1:1 ,
or...
whould i chane it to 3:4 PAL non anamorphic , wich makes the vertical length shorter 720x528
thank you
Erez
Results 1 to 1 of 1
Converting from Mini DV - Problem with Aspect Ratio PAL Widescreen
By Videonisse in forum Capturing and VCRReplies: 9Last Post: 30th Jun 2009, 18:01 -
PAL SVCD - Optimal resolution for preserved aspect ratio?
By Gew in forum Authoring (VCD/SVCD)Replies: 7Last Post: 27th Feb 2009, 15:25 -
Cant view PAL VHS tape. What are my options?
By quantass in forum Video ConversionReplies: 3Last Post: 15th Apr 2008, 11:02 -
PAL aspect ratio 2.35 format to 16:9 NTSC
By chowa in forum Video ConversionReplies: 7Last Post: 2nd Feb 2008, 18:16
