I live in the UK (Pal) and using the trial of DVDLab (due to all the customising the prog can do) . I`ve gone through the dedicated DVDLab forum but it`s more of a bugpost forum with no real questions being answered .
Anyway after making my compilation of music videos and then burning , my dvd player won`t show any of the menu texts or even allow me to navigate at all - this is burning with the preferences set to PAL (full D1) .
But if I burn it as a NTSC project (although it warns me that the project is NTSC but all the videos are PAL , it still lets me burn it ) the menu texts will come up - but the picture is squashed down to 720x480 from the what it should be 720x576 , its doing my head in , any ideas much appreciated .
ps my dvd player does allow menus , projects burned in Ulead MFactory 2 play fine .
The problem right now is that DVD-Lab is a new program.
The author, Oscar, has just released version 1.2.1
Give that one a try, he has fixed several things. His situation is, he lives in Canada, so can only test on NTSC. He has testers in Britain and Europe, but of course they are slower to test and find errors. They have to report to him, he has to try and fix it blind, then send them the patch, they test it, etc etc.
The program is so new, and everyone is learning it. Don't give up.
Have you tried going on the website and posting an email directly to Oscar?--
Will
will a NTSC sony FX1 work in australia were we use PAL?
By gogofilms in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Aug 2009, 17:57 -
How to convert PAL to NTSC keeping the menus?
By user2008 in forum Authoring (DVD)Replies: 8Last Post: 2nd Mar 2009, 10:02 -
PAL to NTSC keep all menus
By Stankia in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 12:45 -
How can I convert PAL menus to NTSC
By alfo666 in forum Authoring (DVD)Replies: 2Last Post: 29th Jun 2007, 23:50 -
using pal material to work in an ntsc format
By rapidondamove in forum MacReplies: 2Last Post: 7th Jun 2007, 16:22
