  1. Hi,
    I use flaskmpeg + lsx encoder to make svcd. But the sound isn't good. So i demultiplex the video and the audio and after encoding the sound back, i multiplex back the video with the new sound file. But tmpeg ( i already try all versions) give me this message at the end of the multiplex : X packet(s) have buffer underflow you may have problem playing this movie
    Could someone help me ? Thanks in advance.
  2. Probably you have selected the wrong type of stream. You have to choose the correct stream type in the drop down list box. If you have SVCD select MPEG-2 program or MPEG-2 Super VideoCD.
  3. No i am sure to have choose the svcd's one.
    thanks for you response.
  4. Maybe some settings were wrong when encoding. Did you also try to select MPEG-1 Auto?
  5. I have the exact same problem with TMPGEnc 12a, 12f and 2.0
    I always select the standard templates (either VCD or SVCD).
    Ignoring the error messages, I burned the discs and they all play fine.
    Don't really know what it is.
    ktnwin - PATIENCE
