I only use TMPEGEnc to convert avi. movies to VCD's but the frames is too small (352x288) thefore you can see all the dots when i watch it on our big TV at home. Is there another program or way to create a VCD that has widescreen resolutions. Becasue all the avi movies have are wdiescreen DVD rips.
it also depends on what options you select to encode at, what is your usual encoding time for a 1 hour 30 film
VCD is 352x288 (for PAL) no way to change that it is a set standard. You can keep it widescreen though by selecting maintain aspect ratio in the settings. Black bars will be placed at the top and bottom which when played on a widescreen TV you will not see. (well you may still see a bit of the black bars depending on the AR of the movie.)
Originally Posted by luckyducky"Art is making something out of nothing and selling it." - Frank Zappa
what i meant was, do you just go for the quickest encode time, if so then thats the prob, i go for the slowest and best quality i.e. my average encode for a 1.5 hour avi-mpg is around 8 hours, and get acxe results, 95% dvd video quality
i can send a sample if you want, if you got msn, then add me -
how can I reduce bitrate and frame rate when converting avi to mpeg-2(dvd)?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2011, 03:42 -
Converting from mts to MPEG 2 I-frame HD in an AVI container
By shaunthesheep in forum Video ConversionReplies: 68Last Post: 8th Jun 2011, 07:08 -
Frame Size
By kamranj in forum Newbie / General discussionsReplies: 18Last Post: 9th Jan 2011, 18:59 -
Help converting mpeg type video with correct frame rate
By DJX in forum Video ConversionReplies: 0Last Post: 9th Oct 2010, 18:24 -
Converting MPEG into a smaller file size?
By ione in forum Video ConversionReplies: 3Last Post: 9th Sep 2008, 22:36
