A friend and I shot the same disc, mine is a better quality I think , and he somehow got the 5.1 sound ...all i want to do is replace his video with my source...is that possible?
side questions... If I wanted to convert froms/vcd to dvd is there a reason i wouldnt want to encode the video?
And if i do its as simple as extracting the mpg with vcdgear and encoding in tmpgenc? or do you suggest other programs?
Not quite familiar with "shooting" discs, but...
What you wanna do is Demux his, and your videos into separate video and audio files. Now just take your *.m2v (the video file) and his *.ac3 (that will be the 5.1 surround) and Mux.
Btw, mux & demux refer to TMPEG's Multiplex and Demultiplex functions under "Mpeg Tools"
And for the other question:
I think you have to as VCDs are MPEG1, while DVDs are MPEG2, but I may be wrong. And it is that simple.
mixing audio and video
By devdev in forum Authoring (DVD)Replies: 5Last Post: 25th Feb 2012, 15:05 -
Live HD video mixing - which software/Hardware ?
By Edwoo11 in forum Software PlayingReplies: 0Last Post: 13th Apr 2011, 16:10 -
Batch mixing audio + video QT
By romanvaras in forum Video ConversionReplies: 1Last Post: 20th Jan 2011, 15:12 -
Help with finding video mixing software
By jackthedj94 in forum Software PlayingReplies: 8Last Post: 26th Jun 2009, 06:27 -
Mixing Audio Tracks in a video
By limesherbert in forum EditingReplies: 1Last Post: 25th Oct 2008, 14:12
